Originally Posted by
Aloicious
more timing can be better for performance, to a point, but not when you're getting KR. and higher isn't better when its causing problems. knock is bad, if you're getting knock at 24*, or 12* (and its spark related) you need to lower the timing, period. detonation will destroy performance and engines, much more than reducing the timing a few degrees. Ideally you want to get on a dyno and tune the spark there. that tune I posted is just kinda preliminary, if you run it and find the KR is totally gone, rock on, then you can experiment, try lowering the AFR, and increasing the spark a little bit at a time, doing logs in between, when you see ANY KR, back off the timing a little, until its gone, then an extra ~2* for safety.
