Applied the AFR over 17 filter and that changed everything
I'm going to undo what I did and put that filter in.
I've had suggestions both ways as to DFCO, so unsure about that.
I'm looking in V8 BBL Pids and the only thing I see that could be clutch related is Transmision State, but I'm betting that is for Automatics anyway. That AFR over 17 did a real good job of getting rid of the clutch lean I think. When I hit the clutch, AFR goes 20+ instantly.
Joe, I saw you recommended 15 for the AFR filter. Isn't that a bit close to Stoich, could really be running a bit leaner than 15 in real world??? Either way, the filter brough all multipliers within 9.9 to 1.1, so now they are just tweaks!
DFCO yes, or DFCO no?
