Results 1 to 3 of 3
Thread: AutoMAF wierd Idling Issues
    Apr 2009
    Default AutoMAF wierd Idling Issues
    I'm in the process of tuning my MAF, run MAF only and DFCO disabled. I've noticed some very undesireable idling issues and could use some advice as to how to deal with them ( or ignore them )
    During a normal commute type drive, no racing around, when I come to a stop with the car in first gear, but clutch pushed in, I get the following.
    RPM stays about 1500+ for a few seconds while at the stop. Then it drops to about 500, then correct up a bit
    When I stop and put the car neutral I get this strange surging between 800 and 1200 rpm. Almost like I'm pushing on the gas to rev it up a bit. Does this all by itself. How special
    Tune and Log below
    2001 Corvette Z06
    Apr 2008
    Did you check AFR? Is your car cammed? if yes you might added more air flow at idle.
    Regards,
    Odd Boy
    Apr 2009
    car is not cammed. I checked my log and found an example between frames 10789 and 11140. Log shows zero mph for this period, but what is strange is that when the rpm surges up, it shows the TP moving up too. I'm quite sure my foot wasn't on that gas as I sat there in neutral. You see it go up 3 or 4 times, each time like I'm hitting the gas. I can tell you sitting in the car, that is exactly what it seemed like. Like somebody was revving it a bit.
    Anybody ever seen this?
    log attached above, frames 10780 to 11140.
  1. Trying to do automaf
    By lownslo in forum Gen III V8 Specific
    Last Post: October 18th, 2009, 09:04 PM
  2. AutoMaf???
    By tatasta in forum Gen III V8 Specific
    Last Post: August 30th, 2009, 01:03 PM
  3. Idling at -5 degrees timing=$ thrown away
    By killerbee in forum Duramax LLY
    Last Post: August 12th, 2009, 01:58 PM
  4. Car reduced power mode/dies after idling with A/C on for a bit
    By Earl H in forum Custom Operating Systems
    Last Post: June 2nd, 2007, 06:13 AM
  5. A/C Idling extremely rough
    By Highlander in forum General (Petrol, Gas, Ethanol)
    Last Post: October 28th, 2006, 10:10 AM
