Results 1 to 5 of 5
Thread: i5 stock radio cayon
    Dec 2005
    Default i5 stock radio cayon
    first time i have seen a stock radio cause a problem but give me heart falure tonight.not good idea to throw tune on wifes cayon night befor leaving on vacation but what the heck.after 4 hours of my heart in my neck thinking how to explane to wife her truck wont start got it going unhooked every thing took radio fuse out and went thought with flash.so what i am wondering do i just pull fuse on all new stuff or only if its loaded for vacation the next day lol
    Did you tell her about this or does she think you spent 4 hours 'preparing the car for the trip'
    It's odd that a factory radio would do that. Was the radio on at the time?
    Oct 2006
    My wife's Trailblazer did the same thing and had another one that I did for a client do the same thing , they were both 06 P12s .
    Both I had to uncheck fast write and it took a while but flashed .
    With this last OS change I did the flash and it went off with any problems , did full flash to a updated TIS OS , then some calibration mods and calibrations only a couple of times .
    Scary when one does it , no start , but EFILive can recover from a failed flash .
    Gil
    2006 Trailblazer
    Dec 2005
    I had done a read like 2 years ago and never got to tuning it to busy doing customers stuff.What was really weird is i just done a 98 trans am so at first it was showing kicking bootloader off wouldnt even try i noticed it was showing the 98 operating system in the status bar so i did a read on my 99 camaro custom o5 went fine so then i went back and did a read on the cayon it went ok and used that read to rebuild tune.started flashing fine then it would lag and you could hear speakers cracking i was thinking not good.so looked on here seen where radio was a problem on some ones took fuse out unhooked battery took computer out hoping it has same plug as my bench e38set up to try bench flash it didnt think it could be but need to try something.then put it back and tryed with radio fuse out and it went though.only other thing i could think was radio was off but they was a cd in it i think not sure wife drives it mainly.all is good now so far after driving it 11 hours today. wife drove most of the time while i sleep off the stess from last night lol thank god for efilive and this forum
    Not exactly an update but I couldnt do a cal flash on a customers P10 today without unchecking the high speed box. Also, the Tune program prompted me to relicense his controller again...weird. Its not reading the serial number properly, I have screen shots showing that the same file has 2 different serial numbers. Finally after resetting everything it worked (using slow speed mode).
  1. Stock Bin
    By teddyls1 in forum Gen III V8 Specific
    Last Post: May 10th, 2008, 05:03 AM
  2. Radio Interference with RR ECM...
    By DuramaxPowered in forum RoadRunner Real-Time PCM Emulator
    Last Post: August 13th, 2007, 08:34 AM
  3. reset theftlock on radio?
    By ssilverado60 in forum General
    Last Post: June 21st, 2007, 04:15 PM
  4. Need stock .bin
    Last Post: September 5th, 2006, 08:25 AM
