Results 1 to 8 of 8
Thread: STFT fixer for VE...check mine out
    Senior Member exploder's Avatar
    Aug 2008
    Default STFT fixer for VE...check mine out
    Ok,
    I went in and followed the instructions for the STFT fixer and went out and made a few logs. What I am trying to figure out is if
    A. Am I logging this correctly to get good data?
    B. Am I applying this correctly to the VE?
    C. Are my STFT supposed to be that far different between bank 1 and 2 or is one of my sensors bad?
    03 z06 auto
    ver7.5.5 custom OS5
    415 ci
    239/255 .624 lift LSr grind
    16psi
    Meth injection
    PLX WB02
    Aug 2008
    anybody?
    03 z06 auto
    ver7.5.5 custom OS5
    415 ci
    16psi
    Meth injection
    PLX WB02
    Nov 2006
    I believe this PID is for RTACS only otherwise use LTFTs.
    If you are using RTACS it's pretty straightforward.
    IMO
    if you are using RTACS, filter out stoich (1EQ) and update the WOT/PE areas only,
    then apply LTFTBEN or STFT fixer the areast hat LTFT or STFT are active.
    Filter out LTFTs that are not equal to 0.00% in the WOT/PE areas.
    This method is only good for non PE areas because when PE kicks in the PID will
    show 1.00 and RTACS will not update cells. (X*1 = no change)
    LC-1 WBO2
    Aug 2008
    It can be used with or without the roadrunner. I guess I just wanted to make sure I was applying everything correctly and if there is anything in addition to what I have turned on and off in the tune that needs to be changed to make the data better.
    03 z06 auto
    ver7.5.5 custom OS5
    415 ci
    16psi
    Meth injection
    PLX WB02
    Nov 2006
    Fuel Trim (Fuel Adaption) Diagnostics
    This is for RTACTS, applying otherwise maybe ok too.
    I tried this once with RTACS and
    because I had no control over PE fueling I never tried it again.
    STFTs influence LTFTs,
    so if you use STFTs to get LTFTs inline then enable LTFTs and find they need adjustment
    what was the point of using STFTs?
    IMO use LTFTs if you are going to use CL.
    LC-1 WBO2
    Aug 2008
    I am running open loop sd not closed...or at least I thought I was.
    03 z06 auto
    ver7.5.5 custom OS5
    415 ci
    16psi
    Meth injection
    PLX WB02
    Nov 2006
    With STFTs enabled the commanded will be stoich (mostly)
    LTFTs will be disabled but the O2's will be running things.
    Use O2 With Open Loop Commanded Fuel Table
    {B4206} Use O2 With Open Loop Commanded Fuel Table XXXXXX
    If you wish to run total open loop disable this parameter and set
    - {B4205} Closed Loop Temp Enable to it's maximum value.
    LC-1 WBO2
    Aug 2008
    I never knew I was running closed loop all this time. I am going to change that and go do it all over again.
    03 z06 auto
    ver7.5.5 custom OS5
    415 ci
    16psi
    Meth injection
    PLX WB02
  1. STFT Idle
    By Mort in forum Custom Operating Systems
    Last Post: October 17th, 2009, 02:46 AM
  2. V1 - is mine broken?
    By 01Z in forum Black Box Logging
    Last Post: September 10th, 2009, 10:05 PM
  3. Want to load up someones else's tune.. Ive had it with mine.
    By waterbug1999 in forum Gen III V8 Specific
    Last Post: June 1st, 2009, 04:37 AM
  4. stft
    By 69camaro5speed in forum Custom Operating Systems
    Last Post: April 8th, 2008, 02:39 PM
  5. Replies: 6
    Last Post: December 16th, 2005, 11:33 AM
