Is there a table that affects fueling based on MAF or anything else???
I am not talking about commanded fueling. But the actual AFR's seen from the wideband.
I have noticed that when the car heats quite a bit more than normal (the tuned in temps)the BENs go haywire. IATs are pretty much where they should be. Car gets rich at higher ECTs.
Is there an ECT referenced table modifier that we don't have access to? Or is this just B4901 out of whack?
