These are 42lb injectors right? Rated at the GM standard of 43.5psi?
Stock regulator and fuel pressure of 58psi?
From the available spreadsheets....I have your IFR's at around 6.110675???
I had the Bosch 'greentop' Ford motorsport injectors for a while.
They were just too big for the 'upto' 8psi I was running.
Duty cycle barely ever reached 30%.
'Dynamics' allow you to counter the 'lean tip-in' issues the Whipple generates as you tap the accelerator.
Do a search for 'lean tip-in' and start reading.
