Assuming you are in CL with PE on,
{B3618} is the commanded AFR for PE.
Change that to the AFR you want per RPM.
On a side note the Logworks software download is at the top of
Innovates support page.
LC-1 WBO2
Just to make sure, what should I check/what should it be? I should be in what the end of the tutorial put me in. You know I am an failure so far at understanding this stuff.. The plan is to buy the learning software that was posted a few weeks back, but the girlfriend (we live together) is going thru cancer so $$ is tight.. this is why I started to try the tuning, is free as i paid for EFILive a few years back.
1999 Trans Am. 10.71 @ 126 - stock bottom end-
My prayers go out to your GF.
For AFR it depends on the octane you have available and your application, N/A or FI.
12.5 AFR at WOT is not too rich for N/A.
LC-1 WBO2
Its cool guys, thanks... She went true surgery and nows its all chemo, shes half done.
DRKPHX and I went for a cruise today... here is the data log. Im just trying to lean it out up top fro max HP.
So, I removed the MAF and did some more ve logging. Question is how much "smoothing" do you do?
Here is the way it is with out.
And a few clicks for smoothing.
Well, I took it for a spin.. looks a little lean up top, I am assuming its because of me taking off the MAF. Should I added a little more in the main VE table in that area?
LC-1 WBO2
