Results 1 to 4 of 4
Thread: Turbo Tuning Help
    Sep 2007
    Default Turbo Tuning Help
    My 4094R turbo has a lot of lag in it at 5800’. Correct me if I am wrong, but my understanding is that decreasing the timing table down low will help spool the turbo quicker. My question is how far out in the table should this adjustment be made (to 1400, 1500, 1600 RPM)? And at what mm3 value should I start adjusting at? How safe is it to use negative degree angle numbers?
    Mar 2008
    Not that I'm any expert and I have a stock VVT, but I would start under 70mm3 and 2400RPMs. From there your going to have to do a lot of logging. EGTs should tell you how low you can go retarded timing = heat.
    06 GMC 2500 CCSB SLT LBZ 4X4
    These views expressed on this post are not my own, but rather randomly generated computer gibberish, and in no way should be used to judge the author's IQ or mental health.
    Sep 2007
    I am planning on doing some testing here pretty soon.
    Lifetime Member LBZoom's Avatar
    Jun 2008
    I'm not certain that lowering timing would help spool or not, I suppose it would in the sense that more fuel injected after the cylinder has reached TDC would potentially generate more heat and create more pressure to spool the turbo, but it may create some smoke here and there if you went too far, and you also run the chance of losing power and efficiency perhaps even more.
    Maybe try squirting a little extra fuel in around 1,000 RPM and start at around 20 or 30mm3, either via throttle base injection quantity or torque based fuel (depends on which Duramax you have) or through the pulse width tables. This will also generate a little more heat while adding a little more power at the same time. When I say a little I mean like 5-10% increases to start with. And if you lose fuel efficiency then experiment with advancing the timing a little bit to compliment the added fuel.
    I'm basing my philosophy on sled pulling trucks...they add fuel and RPM's to get there turbos spooling rather than retarding timing I'd say. But I dunno it's late and I may not be thinking straight as well lol.
    Peace Through Torque
    Punisher Performance DSP5 Tuning, PPE Dual CP3's, 68mm Fleece Cheetah, Punisher Built trans w/ Suncoast Parts, Airdog 165, SoCal 100% Overs, ARP Studs
    2013 NHRDA Sportsman World Champion
    www.PunisherPerformance.com
  1. turbo 5.3 silverado tuning
    By kostelacd69 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 2nd, 2009, 07:01 PM
  2. sts turbo tuning
    By xAustin in forum Vortec V6/V8 Specific
    Last Post: September 6th, 2007, 06:39 PM
  3. AutoVE tuning with turbo
    By WicketMike in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: September 3rd, 2006, 08:22 PM
  4. Turbo Tuning
    By WicketMike in forum General (Petrol, Gas, Ethanol)
    Last Post: January 21st, 2006, 06:43 PM
  5. Turbo & Tuning
    By lplott in forum General (Petrol, Gas, Ethanol)
    Last Post: August 25th, 2005, 01:55 AM
