the trucks ac clutch kicks in at around 900-1000 rpm and anything below that it wont engage. when i force engage it in the real time it works fine. i checked the pressure in the system and its not low. i jumped the pressure switch and it still doesnt work so that sensor isnt bad. no fuses are blown. im thinking it may be something somewhere in the tune causing this, i attached the file so maybe someone could go over it and make sure.
