Ok for some reason today my scanner started not working correctly. I can go out and open any log file and go to the dashboard to review and everything plots correctly...but my problem is my scanner does not have the vertical line controled by the cursor that you can use to drag over the lines to read where you are at....I don't know if I turned something off inadvertently or what. For example if I wanted to see where my AF was on a given log file I can get to the frame I want and physically see the line and where it is on the graph, but when you drag the cursor over it to see exactly what that line corresponds to on the side of the scanner nothing changes and it does not give me a number.
