Results 1 to 4 of 4
Thread: Converting existing tunes to dsp5?
    Jul 2009
    Default Converting existing tunes to dsp5?
    Hey guys im somewhat new to efi but i have a few good tunes that i had been running before i got the switch. I was wondering if im able to convert these to dsp format and put them on my switch or what do i need to do? Thanks.
    Apr 2008
    No you are not gonna run tune for tune. Only a few tables can be modified beyond the stock tune. You pretty set the stock tune which can be any tune you like the best way needed and modify the few tables for each DSP 1-4 for differences. There is a doc on the site describing DSP setup. Read through that to get you started.
    Brian
    Jul 2009
    Oh okay thanks thats what it seemed like i read through it but couldnt find a definite answer. So i can set my main tune as the stock one and switch from there, is copy and pasting tables alright to do?
    Apr 2008
    Yep no problem copying tables from one to the other. Just open up two seperate Tune apps and bring them up. Then cut and paste from one to the other.
    Brian
  1. how to switch tunes to DSP5????
    By browneflatwork in forum General (Diesel)
    Last Post: February 28th, 2011, 10:27 AM
  2. Converting tunes to DSP
    By rjwesleyiii in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 24th, 2010, 04:45 PM
  3. Switching DSP5 tunes with V2 module
    By kdawg62 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 4th, 2010, 02:18 PM
  4. ? Converting dsp5 back to single tune
    By boccheballs in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 29th, 2010, 09:22 AM
  5. Converting DSP2 tunes to DSP5 Tunes
    By BlkMax in forum Duramax LB7
    Last Post: March 6th, 2009, 10:14 AM
