Results 1 to 8 of 8
Thread: Egr cooler delete
    Junior Member getsome's Avatar
    Jul 2009
    Default Egr cooler delete
    how do i get rid of the codes after i take out the egr cooler help me asap
    jim
    Did you disable the DTC's?
    Jul 2009
    how do i do that i dont really mess with efi live that much
    Senior Member DmaxHawk's Avatar
    Apr 2008
    Go to table C6001 and disable all the EGR related codes. (P0401, P0402, P0403, Etc..)
    07 El Bee Zee
    Little faster than stock...
    Jul 2009
    how do i make a smoke tune
    Apr 2008
    pretty full question. The rule behind any engine is to have fuel and air burning equally together to achieve a constant and controlled expansion inside the cylinder. The principal behind the smoke tune is to have a lot more fuel burning than air which creates the soot. So basically add fuel and keep the timing and boost tables the same.
    07 El Bee Zee
    Jul 2009
    What table is the fuel i understand how it all works but i just dont understand how to do it
    Apr 2008
    Gotcha. Basically you will need to look at tables B1102 and B0720. Start increasing the pulse width on the bottom right side in increments. same with the commanded fuel. Do this at your own risk
    07 El Bee Zee
  1. DPF and EGR Delete
    By pONSi in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 13th, 2010, 10:48 AM
  2. dpf delete help
    By escalante127 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 6th, 2010, 08:27 PM
  3. 5.3 o2 and maf delete????
    By kyl3 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 21st, 2009, 10:00 AM
  4. Dpf delete
    By LIL DAVE in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 9th, 2009, 07:24 AM
  5. Idle moving too rich with cooler air temps
    By Ritch in forum Gen III V8 Specific
    Last Post: October 7th, 2008, 09:36 AM
