The table values show 1 mm commanded, but zero is being logged. Can anyone point out why? How can I get it working?
Custom Tuning Services
There is probably a multiplier table causing it to never happen, try making B9122 to something above zero.
just curious why are u wanting it to work???
2006 Chevy Ext Cab SB 2500 LBZ 4x4 EFI LIVE w/ Turbo brake
5" stacks egr blocked no kitty 285/70/17 nitto terra grapplers fass pump custom air intake tru trac diff in rear water/meth inj. race fuel valve
2001 Chevy Std cab 12' ultility bed with pipe rack 3500 2wd LB7 with 6 spd manual custom exhaust system and ppe boost increase valve
Duramax ROCKS
Refinement
2007 CC/SB 4WD, McRat EFI Live, Trans, Trans Cooler and C3 clutch oiling mod by Mike L., SD Sleeves, SoCal Diesel
2002 CC/DRW 2WD, McRat EFI Live, Trans, Trans Cooler and C3 clutch oiling mod by Mike L., SoCal Diesel
