LABELS MAP Sensor Scaler (A/D Counts per kPa)
Parameters Value
{C6301} MAP Sensor Scaler 195.000000 A/D Counts per kPa
I am not trying to go SD just yet, running my MAF but I have a 2Bar Map Sensor installed with the above table scaled so that at (key on) I am reading 30.1 InHg same as 1Bar Map sensor on a friends C5 and my 04 CTS-V.
2 Questions.
1. Can I run with my MAF with a 2 Bar Map installed?
2. If I can, I see that the MAP sensor while into the throttle actually reads more vaccum instead of less. Very Strange.
Side note, could this be why I am having trouble in my other thread with LTFT's at idle http://www.efilive.com/forum/viewtop...303&highlight=
