Results 1 to 10 of 20
Thread: Formula help for Calculated Pid
    Jun 2005
    Default Formula help for Calculated Pid
    I am looking to create a calculated pid for .5V = .68 Lambda and 4.5V = 1.36 Lambda
    I understand how to type all the information into the calc_pids file I just am unclear on the math behind coming up with the equation
    The equation for the AFR .5V = 10 and 4.5V = 20 is
    {EXT.AD1} * 2.5 + 8.75
    Can anyone help me understand how to come up with the same for the Lambda values
    Jun 2005
    Also is there any way to create a calculated pid for Serial Lambda and Analog Lambda? I tried using B3605 however an error occurred when opening the scan tool
    Nov 2006
    Depending on who you ask, Lambda = 14.7AFR
    (AFR/14.7) = Lambda
    or
    {EXT.AD1}*2.5+8.75/14.7
    If you have serial just select EXT.WO2LAM1, why convert it to analog?
    LC-1 WBO2
    Jun 2005
    Thank you, haha I was way over complicating things!
    I now have
    factor 0.0 2.0 .2 "{CALC.LAM_FJO} / ({GM.AFR} / 14.7)"
    As for the BEN for Serial Lambda, I didn't see a pid for BEN lambda serial so just getting ready for it. There is a BEN for Serial AFR just not Serial Lambda
    This is what I will have
    factor 0.0 2.0 .2 "{EXT.WO2LAM1} / ({GM.AFR} / 14.7)"
    Thank you for your clear headed thinking on this one!
    For serial AFR, the pid is BEN1.
    Jun 2005
    Yes, but what is the BEN for serial LAMBDA?
    Jun 2005
    I ordered a universal serial cable from TAq cables to hook up to my FJO, in the mean time I am trying to get the analog external 1 working properly. The FJO read 14.55 while V2 when scanning reads 14.11 making dialing things in difficult. What is the next step in dialing in the Analog?
    Nov 2006
    For BEN from Lambda you will need another PID
    to convert commanded AFR to commanded Lambda:
    {GM.AFR}/14.7
    Why are you basing everything off of Lambda?
    You may end up upside down with all the PID conversions and
    the PCM uses EQ {B3601} anyways which is the opposite of Lambda.
    Use AFR or EQ for tuning.
    LC-1 WBO2
    Jun 2005
    B/c of different fuels and levels of Ethanol and when using methanol as well. Lambda never changes... stoich is stoich
    Nov 2006
    Stoich is different between fuels. Stoichiometry
    Gasoline 14.7 : 1 — 6.8%
    Natural gas 17.2 : 1 9.7 : 1 7.9%
    Propane (LP) 15.5 : 1 23.9 : 1 6.45%
    Ethanol 9 : 1 — 11.1%
    Methanol 6.4 : 1 — 15.6%
    Hydrogen 34 : 1 2.39 : 1 2.9%
    Diesel 14.6 : 1 — 6.8%
    Lambda is going to change and the PID is based off 14.7AFR
    You can change this for each fuel type.
    LC-1 WBO2
  1. Run Spark Formula
    By Gelf VXR in forum General (Petrol, Gas, Ethanol)
    Last Post: March 24th, 2008, 02:07 AM
  2. Formula for final fuel commanding?
    By Redline Motorsports in forum E37, E38 & E67 PFI ECM's
    Last Post: February 6th, 2008, 07:04 PM
  3. Calculated PID's
    By Jason S. in forum General (Petrol, Gas, Ethanol)
    Last Post: March 17th, 2007, 09:55 AM
  4. cylair formula's units
    By redhardsupra in forum General (Petrol, Gas, Ethanol)
    Last Post: September 15th, 2006, 05:25 AM
  5. Replies: 5
    Last Post: April 27th, 2005, 01:26 AM
