Results 1 to 10 of 14
Thread: SLP L92/LS3 package for LS2
    Feb 2007
    Default SLP L92/LS3 package for LS2
    I have on order a L92/LS3 head and intake package, my question relates to injector settings as I believe this package comes with higher rated injectors.
    Has anyone already fitted this package to their LS2? Do they provide the new injector calibrations?
    Oct 2005
    Nice job mate. I hope you ordered a cam to go with it.
    If you dont get injector details, just use marcin's injector spreadsheet and drop the values in. It will get you most of the way there. Accurate enough anyway.
    If you want EXACT values then I wish you luck as they are as scarce as hens teeth. Unless they are GM OEM injectors and you can look them up in another tune.
    2014 VF SV LS3 Maloo.
    Lifetime Member 98 tigershark's Avatar
    Nov 2006
    Default SLP head and intake package
    I read the article around a year ago. I decided to Buy my setup from Tim at Scoggins and Dickey in Lubback TX as they were drastically less and comes with LS7 injectors. The articled show around 475 hp and almost the same torque as the LS7 but there were many SLP expensive extras.
    But after reading the whole article I ordered a complete L92 427 Short block w/ccL76 heads, a nice cam, upgraded springs, manifold, LS7 injectors and fuel rail that had 625 hp/ 605 trq for $7,200.00. The install and a few extras were cheaper than the SLP package, extras and install. That is the best decision I have made and saved me a whole bunch of money.
    98 tigershark
    98 tigershark
    L92/427 w/L76 CC'ed heads n upgraded springs
    4.100 stroke, 4.068 bore w/ 11:1 comp
    Cam, 591 int, 613exhst, 232-246dur@.050, 115*
    LG headers, High flow cats,
    RPM level 5 trans, RPM 3.42 gears, 2800 rpm trq convrt. .
    Special Thanx to Joe and Bruce!
    Feb 2007
    Quote Originally Posted by ringram View Post
    I think they are stock LS7 39lb injectors, looking at the calibrations for an LS7 they are the same or very similar, except the LS7 use delta kPa Map opposed to just kPa
    Still to order a cam, although I have ordered 1.85:1 offset rockers that can be used with stock or the cam in mind providing I get some springs to handle the high lift .634"
    headers and cats coming from mr fish
    I dont mind tackling any of the install apart from the cam swap
    Oct 2005
    Be careful with valve clearance. The intake is a larger valve.
    Feb 2007
    The cam has 8 degrees of negative overlap to keep if emmisions compliant. PVC shouldn't be an issue
    Senior Member MyM8V8's Avatar
    Aug 2008
    Quote Originally Posted by Gelf VXR View Post
    Hi Mate. This is a bit overdue now, what's taken so long?. If you want some help doing the cam let me know. I've got my two post in now.
    If you want a cam, I will be changing mine. I originally bought it with the L92's in mind but I've got AFr's to install now. This cam passed emissions Ok, so I'm looking for a dirtier one now!!
    2005 HSV Maloo Ute, HKE 457ci Stroker LS2 E40, TFS 245's, 255/263 Hi Lift HUC, FAST LSXr 102, NW Billet 102 TB, FLT Level 7 4L65E, CircleD 4200 stall, Duspeed OTRCAI - Mafless, DF 1 7/8" LT's, 3" DiFilipo Duals, Serial LC-1 WB's
    "An Old Dog learning new tricks"
    Oct 2005
    Gareth was that normal UK emissions test or the reduced one?
    Thats interesting anyway. 0* overlap at 0.050.
    Maybe Gelf has gone a bit too small..
    What spec is yours Gelf?
    Feb 2007
    My goal is torque and fairly stock idle, not outright bhp. Some thing along the line of a crane 216/224..
    Aug 2008
    Was the lower one and only missed Euro3 by .1%. WITHOUT CATS!!!
  1. Whats The Best Package For My Application
    By therock in forum Purchase and Shipping
    Last Post: June 18th, 2009, 10:00 AM
  2. EFI live = Incomplete tuning package!!!!
    By NASABlue in forum General (Petrol, Gas, Ethanol)
    Last Post: February 9th, 2009, 04:56 AM
  3. What EFILive package to get?
    By Whodunnit in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: August 14th, 2007, 03:49 AM
