attempted to flash 2010 camaro ss and labeled it as e38. at end of flash it shows screen saying unrecognized. do not know what the reason is. any suggestions are much appreciated.
school of automotive machinists
*block/internals - theory,assembly, & machining -graduate-
*cylinder head - theory,assembly,& machining -graduate-
*cnc machining - current
Doesn't the Camaro use an E67?
LC-1 WBO2
Also, have you tried to read it (and save to file) first...?
could the software be out of date. have tried to download only to see a 404 not found web page pull up.
What version of the software and firmware are you using?
Download Software
LC-1 WBO2
software was out of date
