Results 1 to 9 of 9
Thread: Anyone else BBL shut itself down after about 40 - 60 minutes?
    Sep 2007
    Default Anyone else BBL shut itself down after about 40 - 60 minutes?
    I went on a long 5 hour trip and on the way there I only got 40 minutes of logging data before it shut itself off
    On the way home of the same trip it logged 52 minutes....
    I am logging to a SD card, it's a 2 gig brand name card. I have never had any problems with it, but, this is the first time I have tried to log anything over an hour.
    The low power shut off is at 0 - every value in the flash scan (other than the white back ground blue letters) is completely stock.
    Any ideas???
    07 GMC Sierra LBZ Dually w/ Allison 6 speed automatic
    Crew Cab Dually SLT
    I pm'd Tech Support.
    When you say it stops, does it stop logging and return to the FlashScan menu? Or does it stop logging data but continue to appear as if it is still logging?
    Sep 2007
    Thank you Joe!
    Blacky:
    It stops the 'logging' but continues to show data the entire trip - can not remember if the 'frames' were moving though (i wasn't looking at that part of the screen where it shows the frames, I was looking more at the bottom...)
    Crew Cab Dually SLT
    The next update, due out this week should fix that problem.
    Sep 2007
    Thank you Joe and Paul!
    Crew Cab Dually SLT
    Dec 2007
    Ta! Might it also fix the intermittent problem where after a stop, then a restart, BBL wakes up and starts logging again, but some PID's remain locked at what they were on key off.
    Jun 2006
    I have the problem randomly, too ... any news?
    The BBL has had a major "refit" and the update will be available as soon as the BBR (Black Box Reading) option has made it through the beta test phase.
  1. Hot Engine AC Shut Off
    By shockwave in forum Gen IV V8 Specific
    Last Post: April 6th, 2010, 12:31 AM
  2. v2 still only logging for a few minutes..
    By ringram in forum FlashScan V2 BB Logging
    Last Post: August 5th, 2008, 08:39 AM
  3. Idle after 30 minutes goes rich
    By louis in forum General (Petrol, Gas, Ethanol)
    Last Post: November 24th, 2007, 07:45 AM
  4. fouling plugs every 10 minutes
    Last Post: July 17th, 2006, 12:34 PM
Tags for this Thread
