Results 1 to 10 of 14
Thread: Newbie here needing some help
    Jul 2009
    Default Newbie here needing some help
    Hey guys I am new so please bear with me! I finally did the 411 "swap" in my 97 and it runs! I am running the 02 express van tune and needed some help. I finally got the egr hooked up and still it seems to be running a lil rough at idle, not like it used to be. I have attached my tune file and a 100 frame log file, so any help would be reallly swell!
    Thanks!
    Lifetime Member Aloicious's Avatar
    Nov 2007
    Quote Originally Posted by rennoc442 View Post
    Thanks!
    Hey bro, welcome to the site. there are alot of very knowledgeable, and helpful folks over here. tuning is fun, there's just a bit of a learning curve to it, so don't hesitate to ask if you need help.
    I got your PM over on FSC. I'm not around my tuning computer at the moment, but I'll check out your tune a little later today and see if I can catch anything.
    1996 c1500 gen1e 5.7L - the "LS31", 24x CNP, LS2 coils, modified T56, 12200411PCM running COS3, zz4 cam, custom MPFI, etc. coming soon: Twin Turbos
    Jul 2009
    Very cool man I appreicate it, seems like its alot to learn, but im sure I will figure it out. I just wish there was like someone who I could sit down with and have like a crash learning course in the tuner.
    Since I have a volant cold air intake, what parameters would I change to fully utilize this? Im guessing air and spark? There is more air flow, but wouldnt the maf reconize that anyway? I dont think it would help much for my mileage and performance.
    Nov 2007
    a volant wouldn't change the tune really much, if at all, maybe a fraction of a percent in the VE or something but otherwise not. until you get a wideband and can do an autoVE and actual AFR monitoring we'll just get a generic "performance" tune setup for you, then you can alter it as you see fit, I'll try to explain the stuff, but let me know if something doesn't make sense. its all pretty simple as long as you can understand the science behind how an engine works.
    I still haven't been able to check out your tune yet but we'll get something together. I'm just in and out alot today and tommorow. I'll get to it though, no worries. in the mean time, something that helped me out alot when I was tuning was to cruize around in the tune, and read the table explainations that are provided, as well as just searching around here for interesting topics and how people alter tunes for said topics. like you could search around for 'idle tuning' there's alot of good info on that.
    Jul 2009
    Ok so I drove it today and it runs great! the Idle actually was smooth today, so Im guessing taking it for a lil run helped out. Now I just came back and my ses light is on, gota plug it in and see sup.
    Nov 2007
    after looking at your tune, it looks pretty good, I can't see much really sticking out at me. I'm guessing your code is a p0452 since I don't think the '97s had a fuel tank pressure sensor like my 96. so if you want to turn p0452 and p0453 to not reported that should cure your light, but check and make sure that is the code first.
    I checked out your log and it doesnt show much, the engine torque numbers are kinda worthless I know you don't have a wideband yet, but if you go into the PID secton and open the AUTOVE set of pid's you can get a good idea of good PIDs to log, stuff like TP%, RPM, KR, Spark advance, etc...so your log doesnt really show much, but at least the idle is working better.
    you tune looks pretty good though, save up for a wideband so you can do RAFIG and AUTOVE and you can get into the real meat of it.
    Jul 2009
    That's what I pulled from the pcm.
    Nov 2007
    this is what I've found for it. this text is written for a 99 malibu, but it should be the same for you:
    http://chevrolet.justanswer.com/uplo...1665-Debug.pdf
    if it is actually the EVAP system, it would make sense, because the 96-97 EVAPs didn't have the same setup as the 98+ ones(including the '02 xvan), and we don't have the vent valve hanging off the charcoal canister that the others do, I'm working on upgrading to a 98+ canister so I can have EVAPs correctly set up, but until then I don't have it activated. I'm thinking that is what the code is actually for. and if so, you can just disable it.
    Jul 2009
    OK so far so good, I have disabled the evaps. Now I need to do work on the trans, it shifts too soft, and the downshift is too sensitive, does that make sense? Like when I am on the highway and want to pass, it usually will downshift into 3, but now it downshifts into 2, and im not even full throttle!
    I also was hoping for a lil more power, im curious to see if me turing off all that tq managment stuff actually worked, Im gona do a logged run monday night!
    Nov 2007
    I ditched my 4l60e, I can't help much there. you can try raising the line pressure slightly, and also lowering the shift times. cruize around the trans area, should be some good advice there.
  1. HELP needing another license same truck?
    By djms in forum FlashScan V2
    Last Post: January 18th, 2010, 05:45 PM
  2. Newbie Help.
    By kistlerjm9 in forum Gen III V8 Specific
    Last Post: April 9th, 2008, 08:11 AM
  3. Hi Newbie
    By vxleather in forum General (Petrol, Gas, Ethanol)
    Last Post: February 14th, 2008, 09:15 AM
  4. Newbie needs big help bad
    By LowETz in forum General (Petrol, Gas, Ethanol)
    Last Post: September 10th, 2006, 11:22 AM
