Results 1 to 3 of 3
Thread: Won't connect issue?!
    Aug 2008
    Default Won't connect issue?!
    Went to pull a tune off a 2006 Chevy truck with a 5.3 and here's what happened.
    I have my flash scan hooked up to my laptop and as soon as i plug it into the OBD2 port the flash scan goes dead, screen goes blank. The same thing happens when i hook up my tech 2 as well, screen turns on but won't boot up.
    I verified the both my flash scan and tech 2 still work on another firebird i am working on.
    So does anyone have any ideas? I checked both ground on the plug and they are good, has power as well. I'm lost on what to look for?
    Your truck's OBD-II has a power wire problem... you need to find the wire diagram and probe the port with a DMM.
    Aug 2008
    That was it. Just ran a new hot wire to the fuse box and it works like a charm.
  1. Can't connect to RR fix
    By DrX in forum RoadRunner Real-Time PCM Emulator
    Last Post: September 26th, 2009, 12:31 PM
  2. Can't connect?
    By dbh86 in forum General (Diesel)
    Last Post: November 6th, 2008, 03:35 PM
  3. V1 won't connect
    By chrisr in forum FlashScan V1
    Last Post: August 24th, 2008, 11:08 PM
  4. cant connect
    By mickkk in forum Duramax LLY
    Last Post: December 21st, 2006, 09:40 AM
  5. HELP: Can't Connect
    By tdzee in forum Tips and tricks
    Last Post: May 26th, 2005, 12:40 PM
