Results 1 to 10 of 10
Thread: Bit confused, some help?
    Jul 2009
    Default Bit confused, some help?
    Hi guys,
    Been reading up about efilive for the last few hours, there's still some basic things which I have obviously missed. Well from what I have gathered I think it works this way but if someone can conform or set the record straight for me that would be great.
    How does it work exactly? Is it just software which lets me interface my laptop to my car through the ALDL connector?
    Can i read my LS1 ecu with this, edit it on my computer then flash it back?
    What are these hand held units? do they let you mod the tune without using a laptop?
    Also for every ecu I want to edit, do i need to buy a license? whats the difference between a VIN and a PCM license.
    Also for the actual feed back do i need to use the EFI live scanning software, then based upon the data from that i go and make changes in my tune and flash back up.
    Does it have support for wideband O2?
    Jan 2007
    Quote Originally Posted by hyper24 View Post
    Hi guys,
    How does it work exactly? Is it just software which lets me interface my laptop to my car through the ALDL connector? Software and an interface cable/box
    Can i read my LS1 ecu with this, edit it on my computer then flash it back? Yes
    What are these hand held units? do they let you mod the tune without using a laptop? Yes...V2 is a handheld unit
    Also for every ecu I want to edit, do i need to buy a license? whats the difference between a VIN and a PCM license. Yes...need a licence for each PCM
    Also for the actual feed back do i need to use the EFI live scanning software, then based upon the data from that i go and make changes in my tune and flash back up. Don't HAVE to use the EFILive 'Scan-tool' but it makes things pretty easy having everything in one package
    Yes
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Jun 2005
    Careful with the understanding of the handheld units. The tuning is done on a laptop. However, the laptop doesn't need to be present at the time the tune is loaded in the car. The handheld stores tune files and logs data without being connected to your laptop while in the car.
    Nov 2006
    LC-1 WBO2
    Hyper24,
    Welcome to the forum...
    What year/model car do you have...?
    Lifetime Member 98 tigershark's Avatar
    Nov 2006
    Default Is that a beer summit?
    Hey Joe,
    I think anytime someone joins EFILIve forum or buys it we should have a beer summit.
    98 tigershark
    PS welcome to the Forum Hyper24
    Hyper24,
    98 tigershark
    L92/427 w/L76 CC'ed heads n upgraded springs
    4.100 stroke, 4.068 bore w/ 11:1 comp
    Cam, 591 int, 613exhst, 232-246dur@.050, 115*
    LG headers, High flow cats,
    RPM level 5 trans, RPM 3.42 gears, 2800 rpm trq convrt. .
    Special Thanx to Joe and Bruce!
    Jul 2009
    Thanks for the warm welcome guys!
    Well at the moment I have a VT commodore (Holden, Im from Australia) and a BMW e46 323i 5speed.
    The bmw is being sold (deposit taken) and im currently removing the transmission from my VT to replace the rear main seal. Then that will be sold aswell.
    Im currently looking at later model commodores with an LS1 5.7L
    Just waiting for a nice 6speed to pop up then ill grab it. This will be the weekend car and ill buy another cheapie for a run around to and from work.
    No matter what car I buy for the weekender it will be an LS1, planning on all the usual mods including a cam and head work.
    Tigershark just read your sig, your car looks like an animal, how much power is it putting down?
    Quote Originally Posted by 98 tigershark View Post
    Hey Joe,
    98 tigershark
    Ok, I'll have my cases ready...
    Nov 2006
    Default 650-625 hp crank depending on air temp and fuel oct.
    Hey hyper24,
    You are right LS motors rule. I built the snot out of my 5.7 liter and spent a fortune on the build. I was referred to Scoggins and Dickey in Lubbock TX by GM perf. SDPC had a new 427 build based on the Aussie L92/L76 and they threw in some extras as I have. The motor came from them with 625hp at the crank and 619 trq. Depending on the fuel and temp I have 578 at the wheels w/ 570 trq. Nat Asp.
    The motor cost $7,200.00 shipped. I had way more into my LS1 and needed a new tranny so I put the 427 in w/ RPM level5 tranny, 2800 trq convert, 3.42 rear and adjustable shocks. Many more toys but the guys like Joe and Bruce and the hole EFILive gang on the forum really helped. But with EFILive and the forum was the best money I spent. My Harley has more HP (201) per weight plus a custom 35-75 hp shot nos system and PCM. I have a tuning program for that but EFILive is so much better. In street clothes my car is detuned and legal and I think thats really something.
    Thanks for the compliment. The EFILive guys are really cool and really helped so do not hesitate to ask as they are all great guys and joe has several cases of beer for a beer summit. Hey by the way have any of the EFILive guys ever gotten together for a show or rally?
    That would be great as there are several people all over the globe.
    Take care and welcome,
    98 tigershark
    98 tigershark
    Sweet ride tigershark, mind me asking where exactly nw usa is? Im in Seattle, the true NW!
  1. Im confused
    By nonnieselman in forum Gen III V8 Specific
    Last Post: May 2nd, 2012, 09:16 AM
  2. New guy is confused
    By norsemanberg in forum Gen III V8 Specific
    Last Post: July 5th, 2009, 04:24 PM
  3. Confused on IFR settings
    By samh_08 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 17th, 2009, 03:47 AM
  4. Confused
    By hdmax in forum General (Diesel)
    Last Post: October 21st, 2006, 08:27 AM
  5. Confused after first autotuning run
    By turboberserker in forum General (Petrol, Gas, Ethanol)
    Last Post: June 14th, 2005, 08:47 AM
