Hey guys,
Quick question, I know for example that the timing, pulse, and boost tables on the LBZ are pre-calibrated for up to 120-125mm3 of fuel, so my question is this...What happens if in torque based fuel I specify an amount higher than that, say140mm3 of fuel? Or set B1115 pedal position to desired torque to a value higher than 812 which is all torque based fuel is pre-calibrated to deliver? Will pulse, fuel pressure, timing, and boost all compensate and operate off the chart? If that were the case I wouldn't be able to adjust any of those parameters beyond 120mm3 of fuel right? So like I said what exactly does happen in this event? I haven't logged it to see because I still have a stock tranny and such....Thanks guys!
