I just got efi live and haven't had much time to mess with it. I mainly have used it to change basic parameters ect... with very little engine tuning. I haven't tuned any new efi cars before, so i have a few questions.
1. When WOT doesn't the system go to close loop? If so shouldn't there be a preset a/f ratio it uses, and the o2 sensor adjusts it to that ratio?
2. What tables do you modify to change the a/f ratio? It seems like there is a ton of different tables you could use, not sure which is the best one for WOT and part throttle during normal driving conditions (engine warm etc...)
3. Do newer vehicles come with wide band o2 sensors? If so are you guys logging the a/f off these sensors? or do i need to instal one and hook it up to the v2?
4. Can i save tunes on the v2 scanner and use it to plug into the vehicle and install a new tune? i copied .tun files over in the EFI Live explorer, but when i plug it into the vehicle it doesn't show up as having any files save. I switched it over to use the units internal memory, but it still doesn't work.
I know i need to read more documentation but these are a few of my first quesitons i have to help me get started, so if you could point me in the right direction i would appreciate it.
Also here is another thought of mine after i have read how everyone suggest to change timing on the dyno. One time me and my brother essentially made what we called a "mobile dyno" We used a sensor to pickup the wheel speed of a bike. We then would chart the rpm versus speed versus time. Essenitally this allowed us chart accelleration over time. this way we could put it in one gear and start at about the same rpm and punch it, then go make jetting changes and do it all over again. Now it didn't give us hp estimates (even though we could of somewhat calculated them based on weight, gear ratio, and approximate wind resistance). But what we could see was if we were accellerating faster to tell if the changes made a good or bad impact. Long story short, couldn't you do this by loggin the vehicle speed sensor in your logs so you could tell if your vehicle increased rpm quicker in the same gear after you made timing changes????
thanks!
