Results 1 to 10 of 14
Thread: Unit Selection Problem in VE?
    Mar 2009
    Default Unit Selection Problem in VE?
    For some reason I don't seem to be able to specify units for the 1 & 2 bar VE tables (i.e. B8021, B8023, B8101, B8103, etc.). The only VE field I can specify any units on is B8105. Without being to specify units for the 1 bar & 2 bar tables the linked scan tool data doesn't track the VVE table correctly when I play back a log file, unless I use the 3 bar B8105 table. Anyone have any ideas what the problem is?
    Nov 2006
    It looks like you will have to use metric units for all those tables.
    There maybe a reason for this or maybe it got overlooked.
    LC-1 WBO2
    I 'think' the reason we did this was to account for the fact that the Virtual VE table MAP values are built off the values in tables B8021 & B8023, if those were set to imperial and the Virtual VE table was Metric then it would fail spectacularly.
    "But Ross, I live in the USA, we don't use stupid metric", yes I understand that, but the native units in these ECM's is metric based. I will experiment with allowing the imperial change and see what happens. The Virtual VE calculations might have to be in metric due to the formula used, I'll have to check with Paul on that.
    Nov 2006
    I couldn't have said it better myself.
    It maybe be a little more work for you guys at EFILive but
    supporting imperial units is appreciated by a lot of customers.
    The schools here only teach us how to put on condoms and that
    me must spend more money to avoid going broke.
    Nobody ever mentioned the metric system when I was in school.
    LC-1 WBO2
    Correct, the conversion from coefficients to VE table and back again is not trivial. All of the internal mathematical operations that EFILive performs during that conversion process require the MAP units to be kPa. It could be altered to allow MAP to be specified in other units but doing so is not high a priority.
    Funny, nobody mentioned imperial when I was at school, and I'm 37!
    Maybe this will be Obama's next challenge, though it looks like he's started in Kentucky already....
    Nov 2006
    HAHA!
    There are a few places that erected signs like in the 80's thinking we would switch.
    It's like Soccer, here it will never catch on.
    Why the world decided to use the Metric system is beyond me.
    Didn't the Greeks, Romans and all the ancients use something that resembles Imperial measurement?
    I'd rather walk 10 miles than 16 kilometers, it is shorter.
    LC-1 WBO2
    Mar 2009
    OK well good to know that I wasn't crazy, and there's a requirement for kPa in order for the calculations to work properly. However, even when I tried setting everything to metric, the link between scan & tune data doesn't seem to track properly for these fields.
    HAHA!
    Actually, you can blame the French, they came up with it in the 18th century. But don't feel left out because you stuck with the Imperial system, you are in good company with countries like Myanmar, Liberia and ummm, well, it's better than going it alone
    http://en.wikipedia.org/wiki/File:Me...option_map.svg
    Quote Originally Posted by 4wheels View Post
    Ensure the units in the scantool match (set SAE.MAP to metric).
  1. Strange problem with Roadrunner unit
    By schwoch1 in forum RoadRunner Real-Time PCM Emulator
    Last Post: July 21st, 2009, 07:33 AM
  2. Line Pressure Max/Stock Unit???
    By turboolds in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: October 2nd, 2008, 11:53 AM
  3. Problem Adding New PID Selection List
    By Kevin Doe in forum FlashScan V2 BB Logging
    Last Post: May 6th, 2008, 02:23 PM
  4. Pricing on new V2 Unit??
    By agreif in forum FlashScan V2
    Last Post: November 20th, 2006, 10:23 AM
