Page 2 of 11 FirstFirst 1234 ... LastLast
Results 11 to 20 of 109
Thread: OLSD feels awesome.. issue down low.
  1. #11
    Lifetime Member waterbug1999's Avatar
    Mar 2008
    Quote Originally Posted by SSpdDmon View Post
    What OS are you running? I assume it's for the car in your sig.?.? I might have a stock file that you can load as a "compare" file. Then, you can see what the original values were.
    Yea, its for my 99 TA.
    1999 Trans Am. 10.71 @ 126 - stock bottom end-
  2. #12
    Jun 2005
    Ok - but what's the OS #? It's right next to your VIN when you open the .tun file.
    A4 or M6?
  3. #13
    Mar 2008
    A4 or M6?
    Its an A4... Here is the 0S # 09373372
  4. #14
    Jun 2005
    Quote Originally Posted by waterbug1999 View Post
    Here's the stock file I have for that OS.
  5. #15
    Mar 2008
    Hhmm... B4313 is still 0 all the way down.
  6. #16
    Jun 2005
    That's because cracker is designed to work like an on/off switch based on the MPH thresholds. I've never had to adjust 4313 and honestly, I don't know if it'd do any good to try. Give my suggestions above and in the other thread I mentioned a try. I'm fairly certain it'll get you on the right path.
  7. #17
    Mar 2008
    Ill try it, Thanks.
  8. #18
    Mar 2008
    Whats your take on a cold start... Since I started running in OLSD, it will surge up and down for about a minute or two (im assuming because its warming up) then be fine.. So, what table am I looking for to tweak?
    Im sure its something to do with engine temps, just not sure what table..
  9. #19
    Jun 2005
    First priority is to try and make sure B4307 is in line. Then you can try adding some extra airflow in B4343 to aid startup temporarily (if necessary). One other thing to consider is to look at the timing tables that might be affected during startup. Some factory settings will pull timing right after you crank it up. That can pose a problem if it's too much being pulled.
  10. #20
    Mar 2008
    Will do.. After comparing it to the stock tune you posted, you can see teh difference. Ill put it back to stock and see if it helps/fix's the situation.
    Mine
    Stock tune you posted
  1. Car feels sluggish after MAF removal
    By Alex99 in forum Gen III V8 Specific
    Last Post: August 18th, 2009, 04:36 AM
  2. Code Q for awesome folks that help
    By Gonz in forum Gen III V8 Specific
    Last Post: February 13th, 2008, 01:26 PM
  3. Car feels really flat initially
    By Tordne in forum General (Petrol, Gas, Ethanol)
    Last Post: July 26th, 2006, 05:23 PM
