I think your VE table is not right, all my cars have a nice smooth numbers and your is not. I think you are very lean in your table and are having to make it up elsewhere.
Do you have a log from start to 180 degrees just sitting and idling? No revs no nothing, just idling. Also, leave your key on for 30 seconds or so for your wideband O2 to warm up prior to starting it.
Please get me a log from cold to hot at idle.
230" Dragster - 2000 LS1, 02020003 Speed Density, PRC 2.5 Heads,
MS3 Cam 237/242 .603/.609, Vic Jr. intake, Holley 1000CFM TB,
PowerGlide, 5000 stall converter. 8.70@154 MPH
My Projects Homepage: http://www.horsepowerracing.com
Also, what cam, heads, injectors and fuel pressure?
I have a tune from my dragster that's real close, I'm going to make some changes for you and upload. You can try it for shits and giggles.....
1999 Trans Am. 10.71 @ 126 - stock bottom end-
Try this tune. If your WBO2 is correct you are really lean! I'm sure that it wont be ideal and in fact may be terrible but since our engines are similar and our injectors are identical except I run less pressure it should work somewhat.
How come you dont upgrade to the CO3??
Are you still running OLSD or what?
