Page 15 of 16 FirstFirst ... 513141516 LastLast
Results 141 to 150 of 158
Thread: Correct IFR tables for LS3/LS7 injectors in Gen III
  1. #141
    Quote Originally Posted by Whipped383 View Post
    Attachment 20465
    This appears to be the correct file for the injectors in question
    But I need all the other injector data in gen 3 format
    I'm running behind on a dozen things (sorry, due to my mismanagement)... give me a few days.
  2. #142
    Member Whipped383's Avatar
    May 2011
    Joe did you ever get a chance to work on this?
    97 K1500, 383, 4L60E, Whipple, Stock 14 Bolt with 3.73, EFILive V2, 0411, Marine, #42 Injectors, H-Boost, LC-1, Coming Soon: Intercooler, Trutrac, 4.11 gears?
    03 K2500HD, 8.1 and Allison, Stainless works long tubes, Intake mods
  3. #143
    Ah, I remember doing the interpolation a while ago, but now I don't remember where I put it sorry... I'll do it again, give me a few days.
  4. #144
    May 2011
    Any luck joe?
  5. #145
    I'll have it donein the next day or two.
    ~ posted by phone ~
  6. #146
    See attached spreadsheet, it contains interpolation of injector data from L96 to LS1...
    red L96 labels show where tables came from in L96 file
    green LS1 labels are data interpolated to fit into LS1 tables (tabs show LS1 table id's).
  7. #147
    May 2011
    Thanks joe
  8. #148
    Nov 2014
    how come the voltage table is different?
  9. #149
    Quote Originally Posted by dian View Post
    You mean B3701...? It's not, look at its 4 corners and compare to the original.
    Post a screenshot image of where you see differences... if there's anything wrong I want to fix it right away.
    ~ posted by phone ~
  10. #150
    Nov 2014
    on second thought, i have no idea what the labels are on the l96. i thought thay were hektopascals. just curious.
  1. Correct injectors fixed my issues
    Last Post: May 27th, 2009, 03:12 AM
  2. How to correct WOT for each gear?
    By PRAY in forum Gen III V8 Specific
    Last Post: June 9th, 2008, 09:00 AM
  3. Is this map correct?
    By Loudmouth LS1 in forum Gen III V8 Specific
    Last Post: January 19th, 2007, 02:22 PM
  4. 96lb/hr injectors can be run like stock injectors with EFILIVE!!
    Last Post: July 24th, 2006, 03:14 PM
