Results 1 to 2 of 2
Thread: Advice for getting started on 94 Z28
    New Member Camaro's Avatar
    Aug 2009
    Default Advice for getting started on 94 Z28
    Just to get straight to the point.
    I have a 94 Z28 w-auto trans, absolutely stock. It runs pretty good its in good shape and needs a little tuneup. I'm guessing another optispark replacement. I have purchased a USB interface that works with the EFIlive v4 demo.
    All I want to accomplish now it to be able to monitor the sensors and keep the motor in tune and also change some of the ECM basic parameters such as for instance max speed cutoff.
    Eventually since the motor has over 160k miles is to pull the motor and replace with a mild modified LT1 383 motor. Of course then modifications may be more extensive.
    I understand the 94 Camaro Z28 had a unique flash EPROM?
    Can the EPROM be tuned without removing the ECM?
    What specifically is needed?
    Lifetime Member N0DIH's Avatar
    Jan 2006
    You'll need something like TunerCat or TunerPro. TunerCat has a built in reflash program. You can buy it at TunerCat.com. Or you can use WinFlash and Tune it with TunerPro.
    EFILive V4 only datalogs from what I have gathered, TunerCat is the best at tuning.
    Hope that helps.
    The 94-95 LT1's can be tuned by:
    LT1Edit
    TunerCat
    TunerPro/TunerProRT
    LT1Edit and TunerCat have flash tools with the program, TunerPro doesn't last time I checked, but I could be wrong.
    Quote Originally Posted by Camaro View Post
    I owned a Ford once, ONCE.......
  1. Need help getting started.
    By blownss06 in forum General (Petrol, Gas, Ethanol)
    Last Post: February 3rd, 2010, 06:14 PM
  2. getting started with V2
    By beaukz28 in forum Purchase and Shipping
    Last Post: October 15th, 2008, 01:31 AM
  3. Just getting started need help
    By 99ss in forum Gen III V8 Specific
    Last Post: September 7th, 2007, 03:30 AM
  4. Getting Started
    By DMaxME in forum Duramax LLY
    Last Post: April 15th, 2007, 06:45 AM
  5. How to get started ??
    By Lennart in forum General (Petrol, Gas, Ethanol)
    Last Post: February 4th, 2007, 06:36 AM
