Results 1 to 3 of 3
Thread: 4l80e question
    Nov 2007
    Default 4l80e question
    o.k. here my question. you should be able to divided your Tos by your TIS to get your gear ratio.
    1st gear tis 2003/ tos 812 = 2.4667 so close but i guess it good.
    2nd gear tis 3054/tos 2069 = 1.4760 so second gear looks good.
    3rd gear tis 3106/tos 3114= 0.9974 So the gears are close but little off.
    o.d. grear. tis 2682/ tos 2678 = 1.001 should this be .750
    I can see the rpm drop when the truck goes in O.D.
    4l80e has been rebuilt, racing clutches and shift kit.
    Here is my log file. what do you guys think?
    2006 Trailblazer SS
    Twin Turbo 67 Chevy Truck
    SOLD Truck 2002 Chevy kb turbo t70 5.7l
    Hi aaronr,
    I was looking thru various threads today and I must have previously missed this one by a few months, I do apologize...
    The answer is this:
    In the 4L80E, the TIS sensor reads the reluctor teeth that are machined on the circumference of the forward clutch housing.
    The forward clutch housing is driven by the overdrive gearset.
    In gears 1, 2, 3, the overdrive gearset drives the forward clutch housing at 1:1 ratio.
    In gear 4, the overdrive gearset overdrives the forward clutch housing at 0.75:1 ratio.
    The TIS sensor reads the RPM's of the forward clutch housing.
    If you pick a place your the log chart where the TCC is locked, you will see TCCSLIP is zero,
    and here you can divide engine RPM by TOS and you will find it to be 0.75.
    Nov 2007
    Hi aaronr,
    The answer is this:
    Yea, i had my trans guy look at my log files as well and he said the same thing. Thanks for reply back .
    2006 Trailblazer SS
  1. 4l80e help
    By da69fishman in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 10th, 2008, 12:21 AM
  2. 4L80E in a Camaro
    By Mike@Vengeance in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 25th, 2008, 12:46 PM
  3. L76 4L80e AFM
    By 4wheelin in forum E37, E38 & E67 PFI ECM's
    Last Post: November 24th, 2008, 11:04 AM
  4. 4L80E low rpm shifts
    By pullincrazy88 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: September 16th, 2008, 02:27 PM
  5. Speartech m6 to 4l80e
    By Kilerta in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 25th, 2008, 09:38 AM
