You will have to make your own maps of the tables you want to change
and match the properties to the PIDs you will use.
this is the easiest way to make sure everything works right.
LC-1 WBO2
so in essence can I use the LTFT bank 1 map? If I do use it is there any way to modify it so that it averages the LTFT's from bank 1 and 2 or do I need to only use one side? I'm sorry for all of the questions I'm just new. Is there any way you can tell me what you put under edit map properties-parameters- and rows and colums so I don't screw this up to?
03 z06 auto
ver7.5.5 custom OS5
415 ci
239/255 .624 lift LSr grind
16psi
Meth injection
PLX WB02
In the "new calc_pids.txt" that I posted there is the LTFTBEN multiplier
that uses both banks for an average.
If you want a plain average LTFT PID from both banks look in my sig,
make sure you format the PRN and slot right.
You can open a map that you already have that represents the table you wish to change,
then change the properties, PIDs ect. then save it with a different name.
LC-1 WBO2
PRN slot? Is that like a rotory girder or a chingale valve? So I need to use the LTFT map or the VE ben map? You said open a map that represents what I want to change, I'm not exactly sure what it is I need to change?
03 z06 auto
ver7.5.5 custom OS5
415 ci
16psi
Meth injection
PLX WB02
