Results 1 to 5 of 5
Thread: Help on IFR tables for Fbody/Holden (Ross/Paul)
    Jan 2004
    Default Help on IFR tables for Fbody/Holden (Ross/Paul)
    I was looking at a few tunes tonight with another member (Tordne) and came across something that I don't understand. From viewing stock tunes from a 2002 FBody/2002 VX Series/2004 GTO. Now from my understanding all three of these have the same Fuel Pressure (58psi stock) and injectors. Why the difference in IFR tables from one to the other. The Holden is WAY different and I a trying to understand why. Does anyone know the ratings for PSI and Injectors on the holdens?
ID:	240   Click image for larger version.
ID:	241   Click image for larger version.
    CHad,
    The injectors changed on them in 2001, I have a set of 2000 injectors here that are marked as follows.
    Bosch # 0 280 155 890
    GM # 12555894
    As for the injector flow table, I have no idea why the Holden one is like it is. Someone with more mechanical knowledge than I might know if there is a difference in our fuel system that needed the table defined like that. Another theory, the Engineer at Holden when the LS1 first came out decided to do that and it's just stuck ever since?.
    Jan 2004
    Quote Originally Posted by GMPX
    CHad,
    GM # 12555894
    Thanks. I have a tune from a 2002 Corvette that is different as well and I know it has the same injectors as a Fbody. :( Just wondering.
    Oct 2004
    Just looked on my injectors and they have the following part # 0 280 155 931. From what I can gather (from a very quick search) this is a 28lb injector and was common across the 01-02 range.
    Andrew
    EFILive Crew
    Jan 2004
    Quote Originally Posted by Tordne
    That is interesting. So I wonder why they used a jacked up IFR table on the holdens then.
  1. This one is for Ross and Paul
    By bballer182 in forum FlashScan V2 BB Logging
    Last Post: June 21st, 2008, 10:34 AM
  2. ETC question for Ross/Paul (and anyone else who knows ;))
    By turboberserker in forum Custom Operating Systems
    Last Post: October 8th, 2006, 04:17 AM
