Results 1 to 8 of 8
Thread: Throttle body set screw
    Jul 2008
    Default Throttle body set screw
    How do you determine what the proper setting is for the idle speed set screw? I've installed a new BBK throttle body, performed a RAFIG and AUTOVE, but it would seem everything is hinged on the throttle plate being set at proper opening prior to all this. Is there a correct method to determine where the screw should be set? Trying to get my ducks in a row, any help appreciated. Thanks.
    Jun 2005
    You log IAC steps. When the car is up to temp, they should be ~70 steps.
    Jul 2008
    Thanks for the reply. If I have a cable driven TB, do I need to crack the plate any for bypass air?
    Jul 2008
    I think I found the answer in this post
    http://forum.efilive.com/showthread.php?t=4219&highlight=log+iac+steps.
    Jul 2005
    did you change the effective area scalar?
    Jul 2008
    No, I hadn't changed the value. Thank you for bringing it to my attention. According to what I've found on the forum to determine the effective area scalar-
    Area = pi * R ^2
    R=1/2D, pi= 3.1416
    A= 3.1416 * (1/2D) ^2
    For 80 mm A = 3.1416* (1/2 * 80 ) ^2 = 5026.56 sq mm
    Units for B4349 are %/sq mm
    100%/5026.55 sq mm= .0199 %/sq mm for the 80 mm TB
    This value should be entered into B4349 (ETC Throttle Area Conversion)
    Does this look right?
    Jul 2008
    Thanks again for your input. That's a great spreadsheet. After I've changed the value I need to rerun RAFIG and AutoVE, Correct?
  1. Throttle body bump stop
    By maudyZ28 in forum Gen III V8 Specific
    Last Post: April 27th, 2010, 09:34 AM
  2. Throttle Body Area Scalar
    By finishline in forum Gen IV V8 Specific
    Last Post: August 24th, 2007, 02:05 PM
  3. How is a larger throttle body accounted for?
    By 2000ssnb in forum General (Petrol, Gas, Ethanol)
    Last Post: October 14th, 2005, 03:00 AM
  4. Paul, Throttle body scaler.
    By jfpilla in forum General (Petrol, Gas, Ethanol)
    Last Post: August 22nd, 2005, 03:28 PM
