Results 1 to 10 of 11
Thread: How much power needed for bench top programing?
    Sep 2005
    Default How much power needed for bench top programing?
    I'm not sure if this is the right spot for this, but I'm building a bench top programing harness and was wondering how much power is needed for reading and flashing the PCM. I found a wall plug transformer around the house that has a 12v 200mA output. Is that enough?
    Nov 2006
    12V, same as your car battery.
    LC-1 WBO2
    Sep 2005
    Quote Originally Posted by mr.prick View Post
    I know that silly just want to know if the wall plug transformer I have is enough mA to power the PCM so I can read and flash it in the house with out using a big car battery,
    Nov 2006
    IIRC
    someone here was using one with like 4.5amps.
    LC-1 WBO2
    Aug 2008
    I'm using a Radioshack Universal AC/DC Adapter.... output DC voltage= 12v-24v amps= 4.5a
    No problems whatsoever...
    FLASHSCAN V2 & AUTOCAL
    Jul 2007
    Your wall plug may be (probably is) ac power, you'll have to get or build a rectifier anyways.
    Dec 2005
    I am using a 400W power supply for a computer, just adapted the harness and connected it to a SPEARCO LS1 bench harness.
    Works great, been using it since 2006.
    www.mscservices.net
    Most of the wall warts have a very noisy DC output and I would not recommend one, better off to spend a few extra $ on a decent regulated 12V power supply, 1Amp output rating is plenty.
    The only exception to this is the LBZ/LMM ECM, it draws a lot of power on initial turn on then drops off very fast, it usually trips the over current protection on my 6A supply! However, most supplies will cope with inital turn on currents fine.
    Lifetime Member Cougar281's Avatar
    Jan 2006
    I use a 12v 7.2Ah sealed battery with my bench harness; Works fine for everything I've tried (LBZ, LMM, LS1, LB7, 5 speed Allison, 6 speed Allison, T42 and one or two others). I also have a battery maintaner that I picked up at Batteries Plus that I use to charge and maintan the battery.
    May 2008
    I've used a motorcycle battery, 30A Astron power supply, and a 430W computer power supply. My desktop also has a cigarette lighter port on the front of it. I'm guessing that a wall wart would probably work since I would guess the PCM draws less than 1A. The easiest way to find out would be to hook it up and see how much it draws. I can probably do this when I get home from another round Army fitness training (Hopefully without the black eye this time).
    E85 is NOT flex fuel.
    2003 Chevy S10 4.3L LU3 LS1B Auto
    48 LB injectors
    Race Proven Motors 2114 intake
    T70 turbo.
  1. LMM bench Harness needed
    By MMLMM in forum General (Diesel)
    Last Post: June 2nd, 2009, 08:12 AM
  2. Bench tuning power source
    By killerbee in forum General (Petrol, Gas, Ethanol)
    Last Post: April 10th, 2009, 01:33 PM
  3. Low power mode and power cycle?
    By SV8346 in forum FlashScan V2 BB Logging
    Last Post: March 23rd, 2008, 11:40 PM
  4. 01-02 to 03-04 cpu wiring and programing
    By woody69 in forum E37, E38 & E67 PFI ECM's
    Last Post: August 1st, 2007, 05:47 AM
  5. Bench Harness
    By Biodiesel66 in forum Duramax LB7
    Last Post: May 3rd, 2006, 09:34 PM
