Hey Mike, so I'm thinking in the future here, but with your 24x setup, what all is required to swap to a drive by wire setup?
I'm thinking I'd need at least:
DBW TB
Pedal assembly
TAC
wiring stuff
am I missing something here? this will be with my '96 C1500 L31 in my sig. I'd love to use one of your TB's but it wouldn't work with my whipple setup, however a LS1 style DBW TB should bolt right up. I would be getting the wiring/harness from you though. I may be able to grab a '02 vette TB and pedal setup, and it looks like you have all the pigtails/harness equipment for that.
I'm also concerned how one would go about wiring up the TAC/PCM with the needed cruise control signals? I would think it wouldn't be too hard, I could probably just pull the signals going to the current cable driven cruize control module?
