Results 1 to 5 of 5
Thread: Open Loop Tuning Questions
    Oct 2006
    Default Open Loop Tuning Questions
    I've been running OLMAF for several months now with my LM1 in the car and adjusting the OL AFR and MAF tables. I've gotten it within an acceptable range, but I do notice that the AFR varies due to weather conditions. I pulled this quote from a thread on LS1tech:
    Open loop tuning is NOT easy, it is more difficult because you don't have that automatic correction (LTFT's) so after dialing in the VE and/or MAF there's OL vs ECT to get right so A/F stays somewhat consistent, and of course there's IAT filters, charge temp bias, etc. to get straight so your A/F doesn't end up creeping from IAT heatsoak. No, open loop tuning is not easy.
    Can anyone comment on the parameters for tuning the various tables he mentions in order to get AFR more consistent?
    Jul 2008
    Are you 100% sure you want to run open loop exclusively?
    A properly tuned system with workable narrowband O2 sensors will correct your mixture to ~14.7 AFR (in most cases). Some of the custom OS's (if available for your auto) may also get you there. If you need open-loop exclusively, I am sure someone can walk you through the various tables.
    What are your specific tuning goals or challenges?
    Nov 2006
    Depending on your OS,
    {B4901} {B4902} {B0109} {B3632} {B3633} ect.
    LTFTs tend to be high after OL tuning.
    LC-1 WBO2
    Oct 2006
    Well, I was getting constant 02 sensor codes with my LT's and tried a couple of solutions to that and didn't get anywhere. I decided to go full-time OL and get rid of the 02's.
    So like I said, my wideband reading indicate my AFR is pretty close to indicated on B3605 (which I've adjusted). But I notice that car gets leaner, for instance, when sitting and idling on a hot day with the A/C than it would on a cooler day with A/C off.
    So I'm wondering how the tables mentioned in the quote above can be tuned to minimize this effect. Overall, the OL tune is working well and the car runs good.
    Oct 2006
    Quote Originally Posted by mr.prick View Post
    Yes but what to do with these tables? LTFT's have been disabled.
  1. Open loop or semi open loop still?
    By louis in forum General (Petrol, Gas, Ethanol)
    Last Post: October 18th, 2007, 03:46 AM
  2. Returning and starting tuning in Semi open loop SD mode
    By nitrorocket in forum Custom Operating Systems
    Last Post: July 30th, 2006, 01:56 PM
  3. Using Custom OS for autotuning and Semi open loop questions.
    By Chris81 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 12th, 2005, 10:02 PM
  4. Done tuning SD. What to do with EQ Ratio While in Open Loop
    By ArKay99 in forum General (Petrol, Gas, Ethanol)
    Last Post: July 21st, 2005, 11:34 AM
  5. Tuning open loop?
    By tuff in forum General (Petrol, Gas, Ethanol)
    Last Post: June 1st, 2005, 02:14 PM
