has anyone ever tried to use acetone in the fuel tanks and has anyone had any sucess?
Last edited by joecar; October 20th, 2010 at 09:27 AM. Reason: Fixed spelling in title (allows searches to find this thread)
2001 camaro z28 ss vert with factory slp upgrades, Hooker long tubes, 3"y-pipe to a 4" muffler, ,airlid,s.s.r.a. ,t.c.bypass,descreened m.a.f. 232/234 .595,.598 +2 comp cam with ported and polished stock heads with .650 lift dual springs and a bowl grind. tuned with EFI Live. All combined to achieve 29 m.p.g. and 399 r.w.h.p. with 384 lbs of torque. sold...
Now own a 2015 1LE camaro
No but I knew this tweaker dude back in the day,
that used paint thinner to run a generator.
I ran for a little while.
LC-1 WBO2
http://www.pureenergysystems.com/new...00069_Acetone/ check this site out, supposedly it is supposed to have huge gains in m.p.g
March 17, 2005
"Not more than three oz. per 10 gallons."
It's kind of an old article, there surely is some follow up somewhere.
LC-1 WBO2
must be. My main concern was the effects it would have to your engine? Supposedly its not good with plastic.
At this concentration the only probable benefit is the cleaning effect that the acetone would have on the fuel injectors. As far as the possible problems that the acetone could could cause, keep in mind that acetone is sold in plastic at Bunnings.
It would probably work well on an old gummed up set of injectors, just like the ones that the people on the 'hypermilers' forums seem to test the acetone on.
My preference is for the marine 2 stroke additive that is doing the rounds.
Just my 2 cents worth.
Cheers, Steve
Just got off the showroom floor, now lets fix it.
I've tried it with limited success. I have friends that claim great MPG increases. The best I've seen that I could confirm from it was 10%. I thought it might help me to run mid- grade or regular in my vehicle that requires premium, but it didn't. It also doesn't seem to help with any fuel that has alcohol added to it.
ya i have tried this in many vechiles works good a inj. cleaner
97 2500 ecsb 5.7l/4l80e/4x4 411 pcm /thorley tri-y's/dual super 40's with x (catless)/aem cai/msd 6a and coil/zz4 cam/beehive spring/lm-1
stock sucks
This urban legend is making about its 12th trip around the internet. The idea that such tiny quantities of any aromatic would have any measurable effect on anything other than the ego of the purchaser is ridiculous. Somehow these "secret tricks" always escape the legions of PhD petrochemical engineers who do this kind of thing for a living.
World's First Twin Screw Pontiac GTO
2004 GTO. Blown H/C 408, stage 3 keyboard, billet tires
2017 Chevy SS with dead hooker is spacious trunk
2014 Chevy Cruze. MPG queen with my balls in spacious glove compartment.
www.aussiemotive.com
