Results 1 to 4 of 4
Thread: Tow / haul and shift times
    May 2006
    Default Tow / haul and shift times
    How do I set the settings for the trans once the tow / haul button is pressed? Is that the performance mode in the trans tables? Also, for a 4l80e, can the shift times be reduced? If so where is the table?
    Yes, those would be the "performance" tables.
    The shift times tables are D1108, D1109, D1110 for both 4L80E and 4L60E.
    Mar 2007
    can we run a trigger wire to do this on fbodys? it would be nice to have some lockup on mountain cruises with our stalls. It seems like it might be c1-pin 59
    Quote Originally Posted by Cablebandit View Post
    D0409
    Set it to one switch..
    "Switch types used must be momentary connect to ground."
  1. Adjusting Allison Shift Times
    By Sparky8370 in forum Allison 5 & 6 Speed
    Last Post: June 30th, 2008, 09:24 AM
  2. Shift Times
    By BustedTruck in forum Gen III V8 Specific
    Last Post: January 1st, 2008, 12:53 PM
  3. PIDs for allison shift times?
    By turbo lcc in forum Allison 5 & 6 Speed
    Last Post: July 24th, 2007, 11:45 AM
  4. Need help-Can't reduce shift times!
    By Mach2 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 2nd, 2007, 07:18 AM
  5. Desired shift times...
    By thunder550 in forum General
    Last Post: May 5th, 2006, 11:54 AM
