hi has anyone had a problem with using 5915 to lock timing.i changed 5915 to keep timing from being pulled but now the revlimiter doesnt work or is it a problem when revlimiter is set to 8000 rpms.it has seen 8300 to 8400 many times seems to have started when i started using b5915 to force timing.i am wondering if they pull timing way back to limit rpms but was allways told it was fuel.this is a custom 5 set up
