Results 1 to 6 of 6
Thread: COS5 nitrous table request
    Lifetime Member johnv's Avatar
    Jan 2005
    Default COS5 nitrous table request
    I have a request for a change to the COS5 nitrous tables
    I would like to use them for when i spray meth in boost but instead of pulling timing and adding fuel , i want it to add timing and pull fuel.
    So would need to extent the range of the n2o timing tables to -20
    and maybe lower the n2o VE multiplier minimum to 0.4
    This would give us a great fail safe for using meth and tuning for it, just trigger the operating system with a flow sensor so timing can only be added/fuel removed when meth is actually spraying
    Back yard boost
    347+ T76 = 770 rwhp 10.96 @ 135 mph
    From memory (it was like 4 years ago I did these COS's) the timing table can only pull timing, only because of where it's been slotted in to the PCM code.
    Jan 2005
    Ahh, so not an easy fix ???
    I guess I could Do the reverse and run on the nitrous tables all the time and turn them off when the methanol sprays to increase timing and pull a little fuel, just would have made more sense/been simpiler the other way around
    Back yard boost
    Oct 2006
    You could always intercept the IAT signal but that could get a bit messy as well.
    The Tremor at AIR
    Jan 2005
    Yes, but the problem i have with that is in our cool air at the moment 15-18c ambiant i see IATs very close to that when cruising, they drop from this when meth sprays but will creep back up to that level at the end of a pull through to the top of 4th gear so would be hard to have IAT tables pull timing in that area.
    I am able to run 7* more timing WOT with meth then i can without, makes a huge difference at 15psi boost
    Just after something with more accuracy,a tune that is safe without spraying meth, that will add my extra timing and pull a little fuel as soon as a flow sensor picks up meth flow to the jet/s
    accurate
    relativly simple
    and safe, if meth fails to flow due to pump or elecrical fault or blocked jet/s extra timing will not be added/fuel will not be pulled.
    Back yard boost
    Jul 2003
    we always did the tune with meth and if meth failed, so could the engine.
    What you CAN do.. is put the meth before the IAT system and tune accordingly. If the meth is off.. IATs will be higher and you have direct control over that on the COS5.
  1. Formal Request for COS5 for 1MB PCMs (04 GTO, etc)
    By Kevin Doe in forum Custom Operating Systems
    Last Post: August 29th, 2015, 09:41 AM
  2. COS5 and nitrous setup ?
    By RandyWS6 in forum Gen III V8 Specific
    Last Post: June 2nd, 2008, 12:36 PM
  3. Please explain table A0007 TPS VE TABLE cos5
    Last Post: March 18th, 2008, 06:26 PM
  4. Replies: 2
    Last Post: February 20th, 2008, 12:16 PM
  5. COS5...which table controls the commanded AF <100F ECT at start?
    By onfire in forum Custom Operating Systems
    Last Post: August 30th, 2007, 09:57 AM
