Results 1 to 7 of 7
Thread: "Exhaust Brake"?
    Red face "Exhaust Brake"?
    Is there a way to set the turbo vains to 100% to create a "turbo brake" to slow the truck down with a load when off the throttle completely? Kind of like a exhaust brake in a way.
    Ive got a few crazy ideas so if that doesnt make sence please let me know.
    Last edited by joecar; February 28th, 2011 at 05:39 PM. Reason: fixed spelling to help user searches
    2004.5 LLY Duramax, Compounds, EFILive, EvolvedMS.com 50" Trac Bars, DDP Injectors, PPE Pump, 4" turbo back exhaust, 6" Chrome Stack,
    ATS Trans w/ Triple Loc.
    Evolved M.S, LLC & SS Diesel Tuning
    Jan 2006
    Yes. It has been incorporated into my custom tuning for a couple of years.
    Just load the vane position and boost you want to create during off-throttle operation. Be careful about using 100% at the higher rpms.
    In my application, you have no idea it is there until those grade braking conditions are met, high rpm, no fueling. transparent.
    Custom Tuning Services
    At Higher RPM's whats the highest % you would suggest? just so I dont go dangerously high.
    Jan 2006
    Take it with a grain of salt. I use 95% at 4000 rpm. It is mostly a gut feeling, that 100% vane is troublesome. I do use 100%, but no higher that 3200 rpm, and never for power production
    Okay, I will play around with it and see what I get. Thank you again Michael.
    -Justin
    Feb 2011
    Quote Originally Posted by killerbee View Post
    What a COOL idea !!!
    So, I could command high vane position and boost at 0% load and RPM's over say 1600, yet retain a open vane position the get a LB7 style idle sound?
    Jan 2006
    yes. But you won't get any significant braking with it under 2500 rpm.
  1. what table controls start up decay speed? "how fast it decays out"
    By mvvette97 in forum Gen III V8 Specific
    Last Post: March 19th, 2009, 11:10 PM
  2. EFILive "Classic"/"Legacy"/"Historic"?
    By emarkay in forum FlashScan V2
    Last Post: November 2nd, 2008, 01:48 AM
  3. DIC reads "clean exhaust filter" DPF DELETED
    By ptownbacker5 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 28th, 2008, 04:10 PM
  4. "PCM is in an Unkown State" & "Reflash Failed"
    By foxySS in forum General (Petrol, Gas, Ethanol)
    Last Post: September 8th, 2006, 11:53 AM
