Results 1 to 2 of 2
Thread: E38 pwm cooling fan control
    Aug 2009
    Default E38 pwm cooling fan control
    Hi Guys. Ihave a 62 vette, LS3, 4l65E, E38/T42. Does anybody know how I can operate my aftermarket cooling fan (one single spd 12 volt) using the ecm's pwm signal. Thanks, Gary
    Aug 2006
    Quote Originally Posted by vette5797 View Post
    While I have not personally done this, you should be able to max out the fan tables (to 100% values) to get the signal. With fan off, set the temperature values to 0%.
    24x LS1 PCM on Early Small-Block Chevy and LT1/LT4
    http://www.eficonnection.com
  1. E38 Cooling fans question
    By Chalky in forum E37, E38 & E67 PFI ECM's
    Last Post: September 1st, 2009, 01:11 PM
  2. LS7 E67 fan control
    By rally1 in forum Gen IV V8 Specific
    Last Post: December 18th, 2008, 06:38 PM
  3. Well guys I'm baaaaaaaaaaaaaack!!! Cooling fan OS problems.
    By ssvolvo in forum Gen IV V8 Specific
    Last Post: May 1st, 2008, 10:21 PM
  4. Cant use v2 control panel on pc
    By cLuBsTa in forum FlashScan V2 BB Logging
    Last Post: January 7th, 2008, 05:49 AM
  5. Burping the LS1 cooling system (questions)
    By joecar in forum Lounge
    Last Post: November 21st, 2006, 07:52 AM
