Why won't it work.EFILIVE needs more info for us newbie that don't know
the PC well.A specific problem and maybe a step by step fix??
The manuals are in C:\Program Files\EFILive\V7.5\Doc
or you can download them here
Documentation / Tutorials
LC-1 WBO2
There are a couple hundred pages of set up, opertion and tutorials linked above.
No, it is not easy and there is no "quick start guide" in that tuning is rather complex science project with a steep learning cure.
Don't be too impatient and the results will bring great self satisfaction.
We all started where you are today- overwhelmed.
PowrMax Performance
100 mm PowrMAF
You seem to have an issue with your PC.
Have you tried installing the software and drivers on another computer
and connecting Flashscan?
LC-1 WBO2
What is the problem you are having? You need to be a little more specific about whats going on. That way others on the site can help you out.
Mine2001 GMC 2500HD EC/LB, D/A. 4in MBRP exhaust, AFE Stage II w/Amsoil Ea air filter, ISSPRO boost/Pyro guages, PPE Boost Valve, EFI Live V2, Maximum OD Stage 2 Trans, Amsoil throughout, AirDog150, modded intake horn.
540HP/1056TQDyno'd Danville PerformanceApril 5th 2011
Hers: 2006 GMC Envoy XL Denali, Flowmaster 40 with a bullet style resonator in the back, EFI Live with the help of JoeCar and other great members here.
ALL IS WELL! SONY VISTA LAPTOP needed sony updates and turned off UAC.
THANK YOU ALL FOR HELPING!!
UAC is almost always the villain with Vista.
LC-1 WBO2
