Results 1 to 5 of 5
Thread: Changed PCM having VAT issues.
    Apr 2007
    Default Changed PCM having VAT issues.
    Hello- I had to change PCM due to an A/C issue. Have the new one in it was burned by guy before it was sent to me. Loaded my tune on and truck would not start. Turned of Antitheft and now it will start. VIN is updated, but can not seem to do a VATS relink. When I try it says (turn off ignition then next time on it will relink) I do this and nothing happens.
    Currently my tune is in VATS is off and my alarm will not work right now due to Antitheft off. All of my other tunes from different people all had Antitheft on and worked fine.
    Easy on the termonology I am not a tuner just load em and smoke em. I have the latest version of EFI Live. Thanks in adavance!
    What year? 2001 ECM's can be hit and miss with VATS learning.
    Apr 2007
    truck is a 2002. I did some searching on here and tried a few things but no luck yet.
    Dec 2005
    Go into the tune file, to table #G0301-G0304
    Set G0301 to Enable
    Set G0302 to 30 seconds
    Set G0302 to 10 seconds
    Set G0302 to 1 seconds
    Cal flash the ecm.
    Turn off key for countdown after flash.
    Turn key on to run position, bump key to start for 1-2 seconds, leave in the "ON" position until the security light goes off.
    When it goes off key "OFF" the ignition for 10 seconds, turn key back o"ON" and wait 5 seconds, then attempt to start truck.
    That should complete the re-learn.
    Tony
    www.mscservices.net
    Apr 2007
    Nice one it worked! Have no clue how who had the time to figure out that one but glad they did!
  1. Changed to LS2 90mm on LS6
    By Rusty in forum Gen III V8 Specific
    Last Post: April 12th, 2009, 01:57 PM
  2. What can be changed in the TCM?
    By THEFERMANATOR in forum Allison 5 & 6 Speed
    Last Post: March 24th, 2009, 03:38 PM
  3. Changed my IFR...AFR Is erratic
    By zapp168 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 8th, 2007, 05:19 AM
  4. IAC Changed after TB ported???
    By Ladyredhawk in forum General (Petrol, Gas, Ethanol)
    Last Post: January 25th, 2005, 01:04 PM
