Results 1 to 2 of 2
Thread: pcm swap
    Default pcm swap
    im trying to put my old black box pcm into another truck, as i have it laying around from when i did my 411 swap and his computer has locked due to his crappy hypertech messing up. how do i disable the security feature to use this pcm in his truck? it will not let me do a full reflash
    Aug 2006
    I have never tried this but it is supposed to work. Make sure you have a battery charger (on low) hooked up to the truck when you do this. It is a PDF file that I got off of the MONADAX website. It is NOT mine. I am just passing the info on.
    Jeff
  1. 2.2L s-10 411 swap?
    By haulinit in forum General (Petrol, Gas, Ethanol)
    Last Post: August 5th, 2009, 06:03 AM
  2. 97-02 pcm swap ?
    By TurboVet in forum Gen III V8 Specific
    Last Post: February 19th, 2009, 01:08 PM
  3. 01 s-10 to LS1 swap q
    By cajundragger in forum General (Petrol, Gas, Ethanol)
    Last Post: January 23rd, 2009, 05:48 PM
  4. 01 to 03 ECM swap
    By sweetdiesel in forum General (Diesel)
    Last Post: January 3rd, 2008, 06:03 AM
  5. VIN swap
    By markgammel in forum General (Petrol, Gas, Ethanol)
    Last Post: October 11th, 2007, 04:18 PM
