Results 1 to 4 of 4
Thread: Car feels sluggish after MAF removal
    Jun 2008
    Default Car feels sluggish after MAF removal
    Hi all,
    after driving for over a year in SD mode but with the stock 75mm MAF sensor installed in my Vette, I removed the sensor 2 weeks ago and replaced it with a straight piece of 3.5" aluminum tubing.
    Previously I was getting reduced kPa readings at WOT (96-97), so I thought it would benefit WOT operation if I remove the MAF.
    Well, it improved kPA a little bit on the WOT side, although when I scan for engine torque I don't get any higher values than before.
    What concerns me more is the loss of acceleration in the low end and mid range. The engine is definitely revving up slower after the MAF removal.
    Is this normal?
    Should I put the unused MAF back in to gain back lost torque?
    The engine is a LS1 with ported LS6 heads, very small cam, vararam intake, ported stock TB, LS6 manifold and shorty headers.
    Alex
    Hi Alex,
    You may have to do one more iteration of AutoVE (i.e. with the straight tube).
    Jun 2008
    Hi Joe,
    I am contantly monitoring BENs and have not found any major changes in fueling requirements that would lead to the experienced weak engine response. The values are all within 1-1.5% deviation.
    Are there any other possible causes for this phenomenon?
    Alex
    Post log and tune files.
  1. trans feels like slipping after doing a burnout
    By steve40 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: October 12th, 2009, 02:09 PM
  2. Stock 4L65E sluggish 1-2 shift at light throttle - Dashboard attached
    By pacer265 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 12th, 2008, 05:25 PM
  3. Truck feels sluggish at part throttle
    By Aint Skeered in forum General (Petrol, Gas, Ethanol)
    Last Post: June 9th, 2007, 04:52 AM
  4. Car feels really flat initially
    By Tordne in forum General (Petrol, Gas, Ethanol)
    Last Post: July 26th, 2006, 04:23 PM
