I figured out how to get the stock pcm to idle at a lean AFR with my 96lb injectors. It was 11.2:1 at idle, now I have at at 13.2:1.
Problem is now the car will not idle after I leaned it out. It will sit at 1000 rpm for 1 second and then die both in neutral and in gear. I raised the idle air park/in gear table up and down and it didn't really help. My IAC is at about 60 at idle. Any ideas?
If you tell me how to get the car to idle, :( I will tell you how I can make 96 lb injectors idle lean! J/K :roll:
