Need a little help wth a v2 if i hit f1 its says sample pids do i have bad unit i am using a lm1 serial hookup.
If it says "Sample" when selecting BBL pids, then that might be the sample pid list...
You have to start Scan&Tune and then select Black Box Logging... this will bring up the window you see behind the popup in this pic:
Select your controller and name your pidlist(s) in the blue section (rightclick->Properties on a pidlist).
Drag pids from the yellow section to the green section.
Rightclick->Propterties on a pid in the green section brings up that popup where you can set alternate units.
