Results 1 to 7 of 7
Thread: Problem with RAFIG and BBL
    Member poolshark021's Avatar
    Apr 2006
    Default Problem with RAFIG and BBL
    I logged short term iac correction in gear A/C off (IAC_SD_M) and long term (IAC_LD_M) via BBL. I could see the values on my V2 while it was running. When I open the .efi file up, I can't view these pids in the data (IAC_STD_DMA and IAC_LTD_DMA). I can't do any RAFIG because these pids aren't selected. Any ideas on why I can't see them?
    Apr 2006
    Anyone? Maybe this is in the wrong section?
    I pm'd Paul... it's the weekend in NZ.
    Apr 2006
    Thanks joe.
    Here is a copy of one of the logs if it helps.
    I'll be checking out this tomorrow. Sorry for the delay, been working on the AutoCal beta program.
    There's a conflict in the C:\Program Files\EFILive\V7.5\sae_generic.txt file when converting V8 BBL DMA PID names to V7.5 pass-through logging names.
    Internally, EFILive V7 converts V8 DMA PIDs from having an "_M" extension to an "_DMA" extension. Then the changed name (with the _DMA) extension is looked up in the *BBLV7 list in sae_generic.txt. Unfortunately, the DMA PIDs in sae_generic.txt are listed with the _M extension so they are not found or converted.
    To fix the problem, (in sae_generic.txt) change the _M PID names to _DMA PID names like this:
    Change from:
    Code:
    FUEL_MAIN_M    FUELQ_MAIN_DMA
    FUEL_THR_M     FUELQ_THR_DMA
    DSP5_VOLT_M    DSP5_VOLTS_DMA
    SCALCORVE_M    SCALEDCORVE_DMA
    SCALUNCVE_M    SCALEDUNVE_DMA
    TRQCALC_M      TORQUECALC_DMA
    TRQRED_M       TORQUERED_DMA
    IAC_SD_M       IAC_STD_DMA
    IAC_SPN_M      IAC_STPN_DMA
    IAC_SDAC_M     IAC_STDAC_DMA
    IAC_SPNAC_M    IAC_STPNAC_DMA
    IAC_LD_M       IAC_LTD_DMA
    IAC_LPN_M      IAC_LTPN_DMA
    IAC_LPNAC_M    IAC_LTDAC_DMA
    IAC_LDAC_M     IAC_LTPNAC_DMA
    IAC_FRIC_M     IAC_FRICTION_DMA
    change to:
    Code:
    FUEL_MAIN_DMA    FUELQ_MAIN_DMA
    FUEL_THR_DMA     FUELQ_THR_DMA
    DSP5_VOLT_DMA    DSP5_VOLTS_DMA
    SCALCORVE_DMA    SCALEDCORVE_DMA
    SCALUNCVE_DMA    SCALEDUNVE_DMA
    TRQCALC_DMA      TORQUECALC_DMA
    TRQRED_DMA       TORQUERED_DMA
    IAC_SD_DMA       IAC_STD_DMA
    IAC_SPN_DMA      IAC_STPN_DMA
    IAC_SDAC_DMA     IAC_STDAC_DMA
    IAC_SPNAC_DMA    IAC_STPNAC_DMA
    IAC_LD_DMA       IAC_LTD_DMA
    IAC_LPN_DMA      IAC_LTPN_DMA
    IAC_LPNAC_DMA    IAC_LTDAC_DMA
    IAC_LDAC_DMA     IAC_LTPNAC_DMA
    IAC_FRIC_DMA     IAC_FRICTION_DMA
    That is only a temporary fix. In the next update I will fix the V7.5 software to work correctly with the original sae_generic.txt contents.
    P.S. You'll need to restart the Scan Tool software after changing sae_generic.txt.
    Apr 2006
    Thanks Paul. I was messing around with that file trying different things but I didn't think to change the _DMA part. Glad to see its working right now.
  1. Can't RAFIG
    By macca_779 in forum General
    Last Post: April 17th, 2008, 03:38 PM
  2. help with RAFIG
    By mr.prick in forum RoadRunner Real-Time PCM Emulator
    Last Post: January 25th, 2008, 12:02 PM
  3. Do C5's have RAFIG?
    By PRAY in forum Gen III V8 Specific
    Last Post: December 12th, 2007, 04:44 PM
  4. Rafig Help
    By Dale in forum General (Petrol, Gas, Ethanol)
    Last Post: December 6th, 2007, 04:23 PM
  5. Rafig
    By Gelf VXR in forum General (Petrol, Gas, Ethanol)
    Last Post: November 25th, 2007, 07:39 AM
