Results 1 to 5 of 5
Thread: scan tool user manual mix up
    Jun 2009
    Default scan tool user manual mix up
    whats up with the scan tool user manual it talks about console being (F12) but when using the scan tool (F6) is console and (F12) is DVT , found this out because i was trying to find out what exactly was DVT , i presume the manual is not up to date , anybody Eric
    I believe the user manual has not yet caught up with the software...
    DVT is the bidirectional control... it allows you to control solenoids and to manipulate AFR and spark while in bidi mode...
    You have to select your PCM type to enable the DVT controls that pertain to your PCM.
    Correct, the Scan Tool Manual is out of date.
    The software changes rapidly and it is difficult to keep the manual up to date.
    Jun 2009
    Default thanks
    thanks to both of you for the info
    Senior Member MyM8V8's Avatar
    Aug 2008
    Default Dvt
    I can't seem to find any info anywhere on using DVT on an E40?
    2005 HSV Maloo Ute, HKE 457ci Stroker LS2 E40, TFS 245's, 255/263 Hi Lift HUC, FAST LSXr 102, NW Billet 102 TB, FLT Level 7 4L65E, CircleD 4200 stall, Duspeed OTRCAI - Mafless, DF 1 7/8" LT's, 3" DiFilipo Duals, Serial LC-1 WB's
    "An Old Dog learning new tricks"
  1. Replies: 18
    Last Post: March 1st, 2009, 12:34 AM
  2. Scan tool match tune tool?
    By zapp168 in forum Gen III V8 Specific
    Last Post: March 20th, 2008, 05:27 AM
  3. Replies: 4
    Last Post: January 6th, 2008, 11:47 AM
  4. Manual AFR control with Scan Tool
    By 2002_z28_six_speed in forum General
    Last Post: September 14th, 2007, 07:23 PM
